Thunderbird (local) calendar notifications for events are partly not working
  • 5 majibu
  • 4 wana tatizo hili
  • 16 views
  • Last reply by T-M-
I got a new PC with Windows 11. I installed Thunderbird 136.0.1 , activated the private calendar, and entered events there. For events with a reminder that have a specific duration (e.g., Wednesday from 10 AM to 11 AM), I receive notifications. However, when I create a full-day event and want to be reminded, for example, 1 day before, I don't receive any notification. Additionally, events with a reminder are not shown in bold in the calendar overview (whether they have a specific duration or are all-day events). Can you please help me?
Modified by T-M-
All Replies (5)
The issue persists with version 137.0.1.
Further testing has shown that I only receive notifications if the computer is turned on at the time of the alarm. For example, if I set a reminder for an event at 10:00 a.m. to trigger at 8:00 a.m., but I don't turn on the computer until 9:00 a.m., I do not receive the notification. However, if I turn on the computer at (or before) 8:00 a.m., the notification does appear.
The issue also occurs on other computers.
A prompt bug fix would be appreciated.
Modified by T-M-
The issue still persists with version 138.0
Thank you for the update. There is a rewrite of part of the front end coming, in a few months I think. But I'm don't yet have enough information to say whether this will be fixed then. The good news is calendar progress is being made.
I am also experiencing the problem with my Thunderbird Local Calendars. I am receiving no reminders at all on V138.0.1. This is extremely frustrating as I rely on reminders to get work done.
v139.0 seems to have fixed the problem. Thank you! :)
Modified by T-M-
Uliza swali
